- 12.897
AMC Eagle 4-Door 1981 4.2 Auto Limited
Consumos - EPA Auto pista ( - 2008):: 10.7 L/100 km 26 MPG UK 22 MPG US
Peso : 1565 kg / 3450 lbs
