- 12.997
AMC Eagle Wagon 1981 4.2 Auto Limited
Consumos - EPA Auto pista ( - 2008):: 10.7 L/100 km 26 MPG UK 22 MPG US
Alto : 139.7 cm / 55 pulgadas
Peso : 1573 kg / 3468 lbs
