- 12.155
Alfa Romeo Giulietta II 1.6 JTDm-2 105HP Progression
Relación de Compresión: 16.5
Consumos - extraurbano:: 3.7 L/100 km 76 MPG UK 64 MPG US
Euro NCAP: Alfa Romeo Giulietta II 1.6 JTDm-2 105HP ProgressionEuro NCAP Safety Rating Adultedestrian:Child:Safety Assist:97 %63 %85 %86 % Tested on: 5 / 2010
Batalla: 263.4 cm / 103.7 in
Largo: 435.1 cm / 171.3 in
Ancho: 179.8 cm / - in
Alto: 146.5 cm / 57.68 in
Coeficiente Cx: 0.31
Peso: 1385 kg / 3053 lbs
