- 13.191
AMC Concord Hatchback 1979 258 Auto DL 101HP
Consumos - EPA Auto pista ( - 2008):: 13.1 L/100 km 22 MPG UK 18 MPG US
Autonomia (EPA): : 565 km / 351 miles
Peso : 1411 kg / 3111 lbs
