- 13.141
AMC Spirit Liftback 258 Auto Limited GT 101HP
Consumos - EPA Auto pista ( - 2008):: 13.1 L/100 km 22 MPG UK 18 MPG US
Peso : 1402 kg / 3091 lbs
